Doubler install pics needed
Discussion in 'The Garage' started by BlitzK5, Oct 21, 2005.
  1. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    Anybody got pics on how to mount a doubler to the frame using factory transfer case mounts ie: 203,205 and 208? I would like to see how its done before I take on the project. What combinations can be used?
  2. BlitzK5
    Jul 29, 2005
    288
    Interesting
  3. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    SM465/205 crossmember in the rear and a th400/np205 or 350/203 crossmember up front. You will need to make a notch in the front crossmember for the driveshaft.
    I have both if you need them. :wink1:
    Or you can just build your own.
  4. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I dont know whos rig this is but I saved the pic long ago.
  5. BlitzK5
    Jul 29, 2005
    288
    sweet, Look pretty easy to do. Those look like 208 transfercase brackets which is the exact one I curently got right know under my 208. Do they all use similar ones or are there different ones with each transfercase. Which model uses what bracket?
