Doubler owners - whats involved in the build?
Discussion in 'The Garage' started by BorregoK5, Oct 22, 2002.
  1. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I'm about to pick up an np205/203 pair. Besides the adapter, whats involved internally? Are any of the internal parts completely custom or could they be collected outside the kit?
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    I believe the only custom parts are the output shaft for the 203 range box and the adapter. Other than that it is just a bearing, a seal, and some hardware. Assembly was fairly simple aside from the large internal snap ring. That thing was a little difficult to get in there.
    Hope this helped! /forums/images/graemlins/grin.gif
    Mike
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Well the 203 must bolt to your tranny and the 205 must bolt to a TH400(same as the 205 side of the ORD adapter). /forums/images/graemlins/thumb.gif
  4. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    You will need to replace the output shaft on the 203 range box; this is the hardest part of the doubler build. Have fun.
  5. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    Harry's got his installed and ready to rock. He's also taking this week off of work. Cruise around the corner and take a look if you're home. I'm sure he could give you the lowdown on everything that's involved.
  6. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Most people will want ORD's shifters. I thought I could make the 205 and/or a 203 shifter work. Then looking at how close it all is, I figured it was worth it to buy ORD's shifter kit. Even the kit is REALLY close...
    Then again you are probably a much better fabricator than I.
    Good luck.
  7. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    How does the np203 output shaft differ over stock?
    Is the adapter just that or does it also house a bearing or seal?
    I'm examining all options, looking to mate some 5-speed to a custom np-203/ np-205 doubler. Might buy ORD's or see about just buying some of the internals from them, if they will.
  8. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    The shaft is a couple of inches shorter.
    The adapter hold's the shaft bearing and the shaft into place.
  9. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Silly Mike, you should have crawled under mine at the safari /forums/images/graemlins/grin.gif seriously if you wan tto come to the next meeting, you can check out mine, and i can make you a copy of the ord instructions if you want. its pretty simple really, but the adapter (doubler) does house a bearing and a seal, and i can't remember if they are off the shelf parts or not. Let me know, or maybe if your up my way you can stop by my work or something. See ya.
