DOUBLER question
Discussion in 'The Garage' started by muddyblzr, Nov 21, 2005.
  1. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    alright i know dead horse but i found this wms doubler locally and im in real need of one. heres the problem. the doubler is designed to use a ford 205. is it possible for this one to work with a chevy 205? any knowledge would be appreciated
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    It is for a 32 spline case. That is a ford output that can be swapped into a GM case. If it is the ebay one then also make sure you have a round 6 hole 205.
  3. muddyblzr
    Nov 2, 2004
    623
    yup its the wagoneer one on ebay. its also 32 spline. its right up the road from me im praying it will work. if it were clocked flat for a ford what will that do for a chevy?
  4. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Fords came w/ a 31 spline, so this one has already been swapped to a GM input. Biggest thing, and its already been said, is you will need a round pattern NP205.
  5. muddyblzr
    Nov 2, 2004
    623
    hmm ya ive been told i can swap all the stuff in the ford case over to a chevy case and make it work. im hopin the doubler is clocked correctly and is the right pattern. its right up the road from me
  6. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    If it doesn't work, sell the parts off and I doubt you'll lose money on it.
