Doubler question...
Discussion in 'The Garage' started by Confedneck79K30, Nov 21, 2006.
  1. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    so i cant find exactly what i want to know. so heres a few quick questions
    let me start by saying, its florida and there isnt a lot of rocks to crawl, but id like to have a lower low... that said
    i have a 79k30
    465/205 i can get a 203 fairly cheap from a customer, can you double up with a 205 and 203, or does it have to be 465/203/205?
    tia
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The 203 goes in front on the 205.
  3. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    and a 203 will bolt to my 465, and then i need the doubler adapters?
  4. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    You use the range box from a 203.
    trans/factory adapter/203 range box/adapter(special)/205
    does that make any sense?
  5. dremu
    Feb 27, 2000
    15,965
    456
    East of San Francisco
    You would need a '203 that bolts up to your 465. You would also need to change the input shaft on the '205, as you have the 10-spline variety, IIRC, and most if not all of the doubler adapters require the TH400-style 29-spline or whatever it is. '203's usually came behind an auto, so they're generally the 27-spline for TH350's. Anything else is gonna be rare.
    Anyway, ignoring the fiddly bits above, you split your tranny and t-case, and put the good part of the '203 inbetween them. This gives you the additional 2:1 reduction between the tranny and your '205.
    Make more sense? As others have said you need some adapters and stuff, so it's not an afternoon proposition ... took me a year of gathering parts and then saving up for the Doubler proper ... but if you plan ahead and get everything in the right flavours (i.e. the right input type), it's doable.
    Do check out the ORD page
    http://www.offroaddesign.com/catalog/doubler.htm
    if you've not read it already, as there's lots of good tech info there on what you need to hook what to what, including a more detailed description of what parts of the '203 are used and where and how.
    Also check out NWF
    http://www.northwestfab.com/
    (I believe -- I'm having trouble conencting right now, but that could easily be me :)
    -- A
