Doubler Question
Discussion in 'The Garage' started by 1977k5, Mar 7, 2007.
  1. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    Is there anything preventing me from running a 203 range box with a 32 spline input and a 31 spline (F*rd) output into a Chevy 205 with a F*rd 31 spline input gear?
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    nope, nothing wrong with that. thats what i was going to run, but now i found something else
    ford 31spline input is the cheap alternative to the expensive chevy 32spline input
  3. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    AFAIK the doubler shaft only comes in a 32 spline. So the Chevy would have to be 32. so yes i think there would be a problem.
  4. 1977k5
    May 26, 2003
    9,992
    130
    Thanks. Any significant strength differences between the 31 and 32 spline stuff?
  5. 1977k5
    May 26, 2003
    9,992
    130
    Most companies that make doublers (if not all) have at least 31 and 32 spline intermediate shafts.
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    from northwestfab's website:
    On top of our basic kit you will need:
    - 1 NP203 to mate to your transmission
    - 1 NP205 with either a short 32 spline or 31 spline input gear, or a Dana 300.
    - A 2nd crossmember or custom crossmember
    - A means to shift each transfer case from high to low range.
    - Modify your driveshafts to fit new driveline length.
    noob;) :haha:
  7. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    my bad---ill crawl back in my hole now
  8. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    come on dan, its alright:p:
