doubler question...
Discussion in 'The Garage' started by reddog64, Nov 25, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    How long would the rear shaft (he said shaft) be with a doubler in a k5 with a 6 inch lift and a 14 bolt? Not needing an exact measure just curiouse how bad of an angle it would be and well if it's a bad angle for highway speeds... /forums/images/graemlins/shocked.gif
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    A 203/205 doubler is about an inch longer than an np203 by itself if that helps. I run an np203 with a 14 bolt and a CV shaft for my daily driving and its great..
  3. reddog64
    Nov 9, 2000
    3,325
    I guess that would make sence.. i (brain fart) forgot you dont use the whole 203... DOH!....
    Only an inch longer huh... wow.... alot crammed into a little space...
  4. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    I'll measure mine tonight and let you know. I am running the 400/203/205 doubler with 6 inches of lift and 1 ton gear.
    Mike
