doubler questions.
Discussion in 'OffRoad Design' started by sledheadak, Aug 15, 2005.
  1. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    i have a 203 from behind a 78 chevy th350 and a ford 205 from behind a big block c6.im installing a hp d60 from a 85 ford f350 in my jimmy.do you hake the properadapters to fit this together?and will your shifters work with this combo?since i have a total of $50 in collecting these parts i would like to use them. thanks mike. oh the steering parts i had you make for the fj60 have worked great all summer.the 60 even landed on the drag link and it didnt bend.great stuff.
  2. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    200
    Colorado
    They should be able to help you out with those parts. I am running a Gm 203 rotated 90 degrees with a Ford 205 rotated for ground clearance in my buggy.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The GM-Ford Doubler is actually becoming one of the more popular adapters because of guys doing the same thing you are, so to answer your question, yes, we can build a GM-Ford to use your existing parts. It's the same price as the rest, $770.
