Doubler Questions...
Discussion in 'OffRoad Design' started by reddog64, Nov 25, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I currently have a TH400/NP 203 with part time...
    Is this the right combo to start the doubler?
  2. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    That is one of the better starting points. You can also use a 350/203. You just need a 205 from a 400 or convert one.
  3. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    This is what I have. 400/203/205
    If you can find a 205 from a 1980ish truck it will be 32 spline and solid yoke.
  4. reddog64
    Nov 9, 2000
    3,325
    is that the one I will need? an 80ish one? with NO slip yoke... And does it have to come from a th400....
  5. rodzzilla
    953
    Grinnell, IA
    All of the 205 '80 and newer that I have seen have had the slip yoke. I have not seen a '79 or earlier 205 with a TH400. So it is a toss up, Look for a TH400 version 205 and convert it to fixed yoke, or find a 205 from a TH350 or SM465 and buy the new input gear and have the case machined.
  6. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    hey im selling a 205 , but it needs bored out for the th400 bearing that goes with the 32spline input . i can bore it out for you if you want . O/T O/T O/T !!
  7. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    solid outputs on '80-up do exist, I had one in my '82 crew cab. The 205 you need is a pre-85 from behind a 400. It only runs about $250 or so to convert a 205 so keep that in mind as you're looking.
  8. rodzzilla
    953
    Grinnell, IA
    Cool. I thought they switched everything over to slips in 80. /forums/images/graemlins/crazy.gif
  9. reddog64
    Nov 9, 2000
    3,325
    so any 205 from a th400 will work, but a solid output 205 will save me 250... aka I dont have to convert a slip one... right?
  10. rodzzilla
    953
    Grinnell, IA
  11. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Just so you know, I have an 88 205 from a 1 ton that came from a th400 with a fixed yoke rear! Problem is it has a long shaft input gear, so that I have to convert with the Ford parts 205 I have!! But no Drilling required!
  12. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    The pre-85 205 is best because it will have the short input gear but the 85-up 205's work fine also as long as you keep in mind you'll have to change out the input gear for the short version. Once you get into the 80's it's a tossup as to what rear output you're going to get.
