Doubler shifter boot problem?
Discussion in 'OffRoad Design' started by camok5, Feb 6, 2006.
  1. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I am having a problem with my twin sticks hitting the metal rings that hold the boot on. I have adjusted both of them a bunch of times but they always end up hitting at least one side of the rings, I even bent one of the sticks to try and help. Ths shifters have to much throw and it was causing the trasfercase to pop out of gear. Also the boot has torn alittle because it doesnt allow enough travel for the sticks when the 203 is in high and the 205 is in low. Is there anything I can do to help this?
  2. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Just curious, do you have any type of body lift?
  3. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    Take the boot and plate off and drive around with a big a*s hole in the floor...
  4. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    No body lift. Big a*s hole in the floor not so good for a daily driver.
