doubler shifter
Discussion in 'OffRoad Design' started by four_by_ken, Apr 30, 2002.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    How will the shifter work with a 3 inch body lift? Still ok?
    Ken H.
  2. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    i have a 2" body lift and its at its limits, by that i mean, i had to bend them a little to come up thru the stock hole, and i had to adjust it perfectly to get it to work without enlarging the hole, it just about hitting the edges front and back, witha 3" it would be worse, you could either enlarge the hole , or i thought about making a plate to mount the shifters a little higher so the pivot is closer to the bottom of the floor, the linkage should still work, Thats what i found, hope it works for you.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Previous reply pretty much lined it out, you will probaly run into throw problems with a 3". An offset plate to raise the pivot up may be possible. The linkage should work out OK, we may need a bend in one of the rods where it drops under the 203 shifter pivot.
    We designed it around a 1" so we could cover stock to 2" lift, a 3" body is a bit outside of the parameters we used but not a problem that can't be overcome.
  4. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Well, I talked myself into it.. placed a nice big order from you guys. Just waiting for a phone call back from you to talk about the shifter and body lift problems.
    Ken H.
