Doubler Twin Stick owners, do you get bind?
Discussion in 'The Garage' started by Mudzer, Sep 24, 2003.
  1. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Do any of you get shifter bind when under a load or twisted up a little on the trail? I can shift mine most of the time but occaisionally, it will bind up and not allow me to get just the front engaged. Meaning, I can be in low low 4wd with the Auto tranny in neutral, then try to shift the rear into neutral and it sometimes will not pop out of gear. I even try reverse real quick and back to neutral - still no dice. The linkage is all adjusted properly and does allow for misalignment. Just wondering if anyone else has this problem.
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Yup /forums/images/graemlins/frown.gif Same situations. Not much you can do, but unload the tension on the driveline. Which sucks if you're in a precarious spot.
  3. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    Neil,
    I experience the same problem on occasion. Usually, just when everything is under a load. Really didn't have that problem on the outig to Fulton though. Everything was nice and slippery.
  4. Mudzer
    3,639
    Missouri
    Well, it worked great with exception of when I was "wedged" on Sunday drive. I did get it to kick out once, but later tried it again to no avail!
  5. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    Is it just the pressure on the tires through the drivetrain putting pressure on the doubler shifter forks so much that you can't move them?
  6. Mudzer
    3,639
    Missouri
    Sure is. The t-case does not bind on the body anywhere, so I know its not that issue. Linkage is all adjusted tightly but moves freely on level and in most offroad situations.
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    This is standard, I usually have to shift to reverse, then back to "N" to get the rear to come out. Guys with ARB rears can sometimes unlock the rear diff to take some bind off of it but that doesn't really apply to any of us 14FF types.
