Doubler/Underdrive Question
Discussion in 'The Garage' started by fireplug, Nov 5, 2006.
  1. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    Firstly please don't bother telling me to search, that is how I got to this question in the first place! :D
    I have read over the past couple of hours of searching, a couple of references to running Ford TCases or front axles by using some (all) of the doublers/underdrive cases. In none of the instances does anyone respond to the claim.
    Is this possible? More specifically for my application, would it be at all possible to use a Ford 205 case in a doubler/underdrive application?
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    yes very easily infact. The 203 acts as an adapter to make the 31 slines from the ford t case work:D just need to specify when ordering the doubler or underdrive
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    If you use a ford T-case you need a driver drop front axle.
  4. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    which in turn allows you to better know where your pumpkin be's
  5. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Now THAT is what I was getting at. Like I said the few times this was mentioned it was either vague wording or not mentioned at all. I thought it was the only way logically, yet no one seemed concerned with the huge pita that would cause.
    I do! Cool thanks!
    Though I suppose that would make it easier to find a D60 as Fords are WAY common up here. Hmmmmm
  6. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    A lot of the Ford D60's are hi pinion too...which is much friendlier on front driveline angles.
    Rene
  7. 79k20350
    Nov 22, 2004
    7,757
    Ct
    and the 78-79's are 32.5" spring width...just right for our trucks:p:
  8. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Hmmm this is all getting more interesting. I guess I'll have to start scanning the classifieds for Ford too now!
    By the way, it was kinda funny while searching, to see some of you Gurus that were asking the questions that I'm now asking. 2002...so I'm nearly 5 years behind! :D
  9. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    So are the D60's on F350's then?
  10. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
  11. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    How do you change the perch's on a d60? or do you link them at that point?
