doubler with a 205 from a 350
Discussion in 'OffRoad Design' started by four_by_ken, Apr 24, 2002.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    As I understand a 205 from a 350 will not work. To change the 205 over to a 400 style 205, the shaft needs to be changed. Is this just a shaft swap or does it require some machining to the t-case also?
    Ken H.
  2. rocnwilly
    rocnwilly 1/2 ton status
    Sep 6, 2001
    146
    Ventura, CA
    Yes. You need a new shaft, bearing, seal and machine the case for the larger bearing. I'm doing that this weekend to my 205's. ORD has all the stuff needed. I found it locally. Not real cheap, but finding a TH400 205 is a little more difficult and it will be close to the same price if not a little less.
    Does this help?
  3. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    im going to convert mine too , just waiting on the shaft ....then my different than all the rest dual t case setup goes in woohoo
  4. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Did you get the case machined already?
    Ken H.
  5. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    no , not yet cuz i dont have the bearing to measure /forums/images/icons/frown.gif but itl get done when the shaft gets here ....
  6. rocnwilly
    Sep 6, 2001
    146
    Ventura, CA
    Have new shaft, bearing, and sanp ring. Working on disassembly. After that I have a friend that will machine the case for me. Not sure what a shop would charge.
    One thing I did notice was the price of the shaft wasn't to bad, but the bearing was $47 and I had quotes as high as $70. What really got me was the snap ring that hold the bearing on the shaft. It was $7.50 for one snap ring plus tax and shipping.
  7. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Well, waht was the price of the shaft?
    Ken H.
  8. rocnwilly
    Sep 6, 2001
    146
    Ventura, CA
    ORD has them for $200 with the gear, bearing, seal, and gasket. I paid $117 for the gear and $46 for the bearing.
  9. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Thanks, but I found a t-case that was the correct one. Just need to swap in my non-slip yoke.
    Ken H.
  10. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    rocnwilly got a decent deal, ours at $200 would add a $37.00 205 seal and gasket kit so we're not too far off his good deal.
    That's all you need.
