doubler
Discussion in 'OffRoad Design' started by jp0863, Jul 26, 2006.
  1. jp0863
    jp0863 1/2 ton status Premium Member
    Aug 15, 2004
    566
    clovis, ca
    do you offer a complete doubler ready to bolt in? i have the 203 and 205, i just dont have the time to do the work.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    They don't sell the assembly all bolted together if that's what your asking. You would have to buy the 203 and the 205 and the adapter then bolt it all together once you receive it. Since you already have both the 203 and the 205 it doesn't take much to mate everythig together. I helped Zakk do his and i think it only took an hour or so to mate everything up, then install into rig.
    Actually, it is easier to install the 203 range box after you have installed the internediate shaft that ORD supplies with the kit, then bolt the 205 up to it while the rest is in the vehicle.
  3. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    206
    Colorado
    Because of weight they can't ship a full Doubler setup.
    They will rebuild both cases install the shaft in the 203 and put the doubler adapter on the 203 so it can ship in 2 boxs.
    All you have to do then is install the 203 then the 205 and tighten bolts.
