DPI - Fender Trimning
Discussion in 'The Garage' started by bigbluesuburban, Feb 7, 2007.
  1. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    Below is an original quote from another thread on this forum. At first I was looking at the FRONT end of the fender and admiring the trim job. But then I took notice of the back of the fender.
    Is that trimmed too? If so, can I get really really close up pic of that area. I want to see how you worked the fender trim to look so good. I want to run 35's on my DD with 3.5" of lift. I really don't want to lift any more and the 35's will hit a little with everything in stock trim. But moving the axle forward (redrilling) and doing this trimmming would be the best. BUT, I want to keep my chrome fender trim and such cause she's a perrrrty truck and all.
    Thanks if you can offer some advice.
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Here's a couple more pics. The rear of the fender is trimmed substantially.
    I cut and re-welded the inner fender mounting brackets to gain more clearance and to keep the inner finders.
  3. K30Blazer
    K30Blazer 1/2 ton status Premium Member
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    gotta be one of the best trimming jobs I have ever seen. Looks factory still.
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    That was the goal! :D
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Where is the moulding from? I would like to add some to mine, just not chrome.
  6. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    It was the factory molding that I persuaded to fit the new curves.
  7. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    The red rings look good man!
  8. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Thanks, The first pic shows the aluminum rings. But those only lasted a couple trips out before they were thrashed.
    I then got the steel rings, but MRT uses the bright orange powder coating. Red and Orange don't go together, especially in Oklahoma. So I had them coated with red to match the rest of the rig...
