drag link ends...
Discussion in 'The Garage' started by 79k20350, Jan 7, 2006.
  1. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    i got a used ord crossover drag link w/ very new ends. the only problem is the boot are torn. can i replace just the boots? any part numebrs? one more thing. ord use tre for there drag links right? or do the use dre for there tie rods? Thanks guys!
  2. 79k20350
    Nov 22, 2004
    7,757
    Ct
    anyone?
  3. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    i think IIRC if you go to advance auto or auto zone they have one of those bins with boots you can pick though and find some,
    but again i cant remember for sure
    LUKE
  4. 79k20350
    Nov 22, 2004
    7,757
    Ct
    hmm never seen a bin like that:confused:and i do have to stop there quite often:doah:
  5. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    I think from the post i made to ORD that they are actually TRE's. They are an ES2010R and a ES2010L, i just bought a new pair for my crossover yesterday. I'm not sure where you can buy just the boots but i do know you can get them and i think they are made of urethane and not rubber.
  6. Afireinside
    Afireinside Registered Member
    Jan 22, 2005
    61
    Aurora Colorado
    Autozone has them in the help section made from rubber.Also you can find poly.ones but im not sure if you have to buy a whole kit.
  7. 79k20350
    Nov 22, 2004
    7,757
    Ct
    thanks guys!
  8. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    hey i know this isn`t under the topic fully but could replacing the draglink cause the front end to be stiffer? wat could a squeaky type noise be from when i push on brake pedal and sometime a grinding or hissing noise when i accelerate a little? also i am having probs with my alternator. mine was making the noise that a bearin makes when it is worn and when i bought a reman alt it did the same noise so i got another reman and it did the same thing??? it has gone away but still does once in a great while. any idea??? info would be greatly appreciated
