drag link ends..
Discussion in 'The Garage' started by 86Cucvbeater, Nov 12, 2006.
  1. 86Cucvbeater
    86Cucvbeater 1/2 ton status
    May 24, 2005
    428
    north carolina
    which end is better. first one is ORD, second one is UFO. UFO is cheaper and ill prolly go with his but why does ORD use the other kind? school me please, my draglink with heims got bent so i need to order another one quick, figured i'd ask u guys what u use
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
  3. 79k20350
    Nov 22, 2004
    7,757
    Ct
    works now...definetly the first one
  4. 86Cucvbeater
    May 24, 2005
    428
    north carolina
    why? which ones are the ES2026R and ES2027L's? those are the ones to get i hear. also, why do some guys want both ends right hand threaded? some benefit?
  5. 79k20350
    Nov 22, 2004
    7,757
    Ct
    the reason why is the end itself is much shorter making it stronger and less prone to damgage.
  6. 86Cucvbeater
    May 24, 2005
    428
    north carolina
    damage from what? lol bending i guess. but anyone actually bent one of these tre's on a draglink??
  7. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Yeah, but it was on a ford
  8. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Definately the top pic, it is an ES2010L and an ES2010R. They are a 7/8" x 18 thread and the shortest ends you can get which makes them much stronger than the other ones which are known to bend fairly easy.
  9. 86Cucvbeater
    May 24, 2005
    428
    north carolina
    i found a site that answered some questions. might be helpful to others
    http://www.partsmikeparts.com/tre_comparison.htm
    thanks 4x4high i found the info i guess the same time as u posted that. i saw in another post u bought from trevor at wfo but it seems he sells the ES2026R and ES2027L which as i understand now, are weak. did u get your tres somewhere else? you said the top pic are the ES2010's but on the ORD site they say they use GM 1 Ton TRE's. in the parts mike link it says the ES2010R & L tie rod ends came stock in Dodge W250/W350s. i wonder if i could just go to napa and get a set. just what vehicle to i get them for chevy or dodge?
  10. 86Cucvbeater
    May 24, 2005
    428
    north carolina
    do the ES2026 and ES2027 not handle more angle than others? is that not why some guys use them?
  11. 86Cucvbeater
    May 24, 2005
    428
    north carolina
  12. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    My first set of TRE's came from ORD and they are the ES2010L/R my next set i bought from my work. The ES2010L/R are what are the strongest ends and they are actually Dodge ends and not Chevy ends.
  13. 86Cucvbeater
    May 24, 2005
    428
    north carolina
    Do u know what years the ES2010's came in the dodge trucks? i would like to compare their price locally with the 85 blazer TRE's.
  14. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    There is a definite price difference as there is a strength difference.
  15. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I have no idea what the year application is but the parts store can give you a price by using the part number.
  16. 86Cucvbeater
    May 24, 2005
    428
    north carolina
    Trevor at UFO replyed back to my emails and cleared up some things.
    Trevor <trevor@wfoconcepts.com> wrote:
    Jason,
    You need the bent draglink to clear your cross-member. I only
    sell the 1.5"x.219 Wall DOM draglinks now. They are CNC bent, and then
    have inserts welded in each end. They will not bend or break. They are
    $95. I have them in stock and ready to ship.
    As far as the ends, Off-Road Designs sells the shorter ends.
    They are made by Tera. They were designed to replace the Chevy 2010L
    and 2010R. I sell them also, they are $35.99 each, and come with the
    jamb nut. If you try to buy that part # at your local parts store, it
    will not work. The stock 2010's do not generate enough angle for a
    draglink. They only pivot around 15 degrees. They will bind and wear
    out. I use stock draglink ends most of the time. Those are the long
    ones that you see on the internet. They will get to around 40 degrees
    of angle. They have a double pivot ball socket, so they will not bind.
    The part #'s are ES2026R, ES2027L. They do not come with jamb nuts. I
    sell the jamb nuts for $5 each. I usually try to sell the customer on
    the stock ones, so they can easily be found at any parts store. If you
    use the Tera ones, you have to buy them from a shop. It works out to be
    about the same price when you add the cost of the jamb nuts. The other
    nice thing about the stock long ones for guys on a budget, is that when
    they go to crossover, they can simply re-use the draglink ends that are
    on their stock push and pull setup.
    I hope this isn't too much info for you. Let me know if you
    have any other questions. Trevor WFO
    next..
    The 2010 can be found on both Chevy and Dodge trucks. I don’t think it is any weaker or stronger. Parts mike is not wrong, he is just leaving some info out. We both get all of our rod ends from the same place. We work together all the time. Any rod end will bend if you hit it directly on something. I find it pretty hard to hit your draglink on something. If you are worried about it bending, you should go with the Tera style 2010’s. They are short, as well as matching. If you were in a bind, you could go to a local parts house and get a standard 2010 to get you out of somewhere. You could then replace it with the Tera style 2010 that has the angularity that you need. Trevor, WFO
    next..
    Their statement is correct, it doesn’t really matter if you have 2 rt hand thread ends. However, those ES2234R ends are just standard chevy tierod ends. They won’t get the angle that you need on a draglink. It is their cheap and easy way out. You wouldn’t want those ends. Trevor WFO
    hope the info can help someone!:wink1:
  17. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Well, i don't know what to tell you other then the off the shelf ES2010L/R's that i bought from my work (car quest) are a double pivot ball and they have plenty of angularity.
    EDIT: I re-read your original post and you said your draglink with heim ends got bent. Does this mean you drilled out the taper in your knuckles or steering arms to accept a bolt if so then you cannot go back to TRE's unless you replace the knuckles/steering arms so that they will have the correct taper in them again.
  18. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Or you could weld fill, drill and then retaper.
    Ira
