Drag link is to long
Discussion in 'The Garage' started by 1987Chevy, Jul 24, 2005.
  1. 1987Chevy
    1987Chevy Registered Member
    Jun 29, 2005
    51
    Connecticut
    I was wondering if this happened to any one else. I am running a 4" lift and decided to switch from a stock pitman and raised arm setup to a drop pitman stock arm set up. When I went to hook up the drag link even with it adjusted in as far as it would go the steering wheel would not center it was like half a turn off. I was wondering if this happend to any one else and if so what did you do to fix it? :confused:
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    Are you sure that the steering box is centered when you are adjusting the draglink? Also, it is possible the previous owner put in a longer drag link in to accomodate the lift.
  3. 1987Chevy
    Jun 29, 2005
    51
    Connecticut
    Yes the box is centered and I put the lift on my self and I replaced the drag link with a new one that is exactly the same as the old.
  4. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Front springs may have non-standard centering pin location, or there is a "zero-rate" block installed to move the axle forward???
    Moving the axle forward will improve clearance of the front tires when flexing, but will also create the problem you describe. I had to cut down my stock draglink to make up for the difference.
  5. 1987Chevy
    Jun 29, 2005
    51
    Connecticut
    My springs moved my axle forward a 1/2" to 1" I'll see how cutting down the drag link works.
  6. 1987Chevy
    Jun 29, 2005
    51
    Connecticut
    just cut the drag link down and it fits real good now :D
