drag link on 10 bolt...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dyeager535, Feb 24, 2001.
  1. dyeager535
    26,975
    is there any special trick to turning the "sleeve" that the two clamps hold tight? My steering column is slightly off center, and I know thats how I fix it, but the dang thing won't turn. Sprayed it down with cleaner, then WD-40. I loosened the clamps up as far as possible (removed bolts) and took a pipe wrench to the sleeve, then stood on the pipe wrench. It wouldn't budge. Tried going either direction, and no movement. The threads really aren't that corroded, I'd figure it would move easier. @ around $75 to replace the whole assembly, making this one work would be a nice alternative. Anybody got a trick to this? Thanks!
    Dorian
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    I think you just answered your own question! I had that problem too many times, so I did the easiest thing: I got new one. If you get a new one, get the adjusting sleeve with the two ends. It will make your day go faster and better since the threads will be new and clean. Helpful tip: glop on some anti-seize on the threads before assembling the three together.
  3. jerseyk5
    jerseyk5 Registered Member
    Jan 26, 2001
    42
    NJ
    Try heating it with a torch and then spray it down with some penetrating oil while its still warm. Might have to do it a couple times. When you get it undone you might want to apply some anti-seize compound for future adjustments.
  4. Grim-Reaper
    7,385
    Atlanta
    PB Blaster is the best stuff for freeing up stuck stuff. soak it down a few times durring the week and give it a try again in a few days. Try taking a pry bar and spreading it at the slot some.
    $75 is a little steep for that. Autozone is where I got mine and the ends are about $22 each and the sleeve is like $7. Thats life time ends.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  5. dyeager535
    26,975
    Heh..my friend just said the same thing...except this sleeve is solid! No way to spread it, unfortunately. No autozones here, wonder if I can order on the net from them. May check some other online places too.
    Dorian
  6. baldbandit
    baldbandit 1/2 ton status
    Jun 16, 2000
    282
    Marshall TX
    I wouldn't buy from Autozone. No offense to anyone intended, but i found that autozone parts are not of good quality. Even with the lifetime warranty, who wants to be replacing the same parts every two or three months?
    baldbandit
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    If you replace it, get MOOG parts. they are the best steering parts, and not that expensive. you can get them at O'Reilliy or NAPA.
    90K5
  8. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I just got them at NAPA. $25.00 each for the ends and $9.00 for the sleeve. A good investment too.
    Become one with nature.............Then marinate it,,
