drag link or pitman
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nyyef, Oct 12, 2000.
  1. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    when lifting a truck, which is better to change the drag link or the pitman arm?
    Knife.
    knife.coloradok5.com
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I used a 4" steering arm. They are about $55....
    Not sure which is better to use.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    I change the steering arm also. Goes to the knuckle. Don't think they make drop pitman arms. An extended drag link does nothing to change the higher angle that the rod ends are now dealing with.
  4. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    They do make a 2" drop pitman arm. I'm using one, but can't wait to get it off as some of the teeth have broken off! Only about 1/2 of the tooth contact area (which is small anyway) is remaining. I do recommend the steering arm, which attaches to the knuckle...its good for about up to 6" of lift correction. I don't really care too much for the drop drag links, as if you get too much protrusion from the ends, they bend!! I've bent them!!
    ken
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    A dropped (S-shaped) drag link does nothing to correct steering geometry. All it does is improve the angles that the drag link ends operate at. A dropped pitman arm does help correct the steering geometry, but it places even more stress on the steering box, and the known weak point in the frame where the steering box attaches. The best solution is a raised steering arm, IMO. God bless small lifts and cut fenders.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  6. BigBurban
    BigBurban 1/2 ton status
    Jun 14, 2000
    237
    AZ
