Drag link
Discussion in 'The Garage' started by ftn96, Jun 20, 2002.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I've got both steering braces, new Tie-rods new ball joints and here lately Im getting lots of popping going on up front sitting still or at low speeds turning. So my guess is that the joints on the ends of the drag link are worn and causing this.
    Has anyone ever had one come apart while driving and how bad was it to control if at all till you came to a stop? /forums/images/icons/shocked.gif
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    check your u bolts on the front axle...sounds to me like they loosened up on ya a little /forums/images/icons/grin.gif
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Mine does that too, but it's the sector shaft sliding up and down in the gear box /forums/images/icons/blush.gif Also as mentioned, check the u bolts and your sway bar.
  4. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    /forums/images/icons/laugh.gif What sway bar? /forums/images/icons/laugh.gif
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Check the shackle bolts for the front shackles too...
    My drag link ends were pretty bad but never came apart, plus they're cake to change and not even that expensive.
    Rene
  6. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Will do tomorrow. I did check the steering bolts. They got tightened some what, also greased all the joints and found my lower ball joint driverside zerk was sheered off. /forums/images/icons/smirk.gif Looks like tap and die time or new ball joint. /forums/images/icons/smirk.gif
  7. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I also have a popping at low speed or stopped while turning /forums/images/icons/frown.gif . I actually narrowed it down to the front spring bushings and shackle bushings being in need of some grease. I guess I should have done that when I first installed them /forums/images/icons/tongue.gif !
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the springs will make a fair bit of noise in the situations you described.
    smear grease between the leaves and see if that quiets it down
