DRAG LINK
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by DANL, Oct 26, 2002.
  1. DANL
    DANL Registered Member
    Mar 24, 2002
    18
    MEM TN
    I need to replace the drag link on my 72 K5.
    The one currently on it is one piece. All I have seen for sale are three piece ones. Any recommendations on which one is best to use and where to get a new one piece drag link?
    Thanks!
    ...Dan
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I've never seen a 1piece...
    I like the 3 piece better because you can adjust it to get your steering wheel straight after a lift.
  3. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    The one piece desgin is less desirable, and I belive very hard to come by as far as rebuilt units. I think your only option is to get a 3-piece from the wrecking yard for thr sleave, then buy the ends from the parts store. I personnly would upgrade to the adjustable desgin myself.
  4. DANL
    Mar 24, 2002
    18
    MEM TN
    Guess I will get a three piece.
    Thanks for the info.
    ...Dan
  5. daveo
    daveo Registered Member
    Mar 19, 2002
    11
    Masonville, CO USA
    Dan;
    I may still have a 1-piece from my '71. I had to replace it w/a 3-piece when I did my lift. The 1-piece won't fit (too short) if you lift - even w/raised steering arm. IMO 3-piece is better (and will be required if you decide to lift), but if you're keeping your K5 suspension stock and set on 1-piece, let me know - I'll check if I have it and condition.
    Dave O.
  6. DANL
    Mar 24, 2002
    18
    MEM TN
    Thanks for the response Dave.
    I ordered a three piece from Chevy Duty.
    Should get it tomorrow. If it doesn't work out, I'll contact you regarding the one piece.
    ...Dan
