draglink contact to Shock?
Discussion in 'The Garage' started by Lance, Aug 13, 2003.
  1. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    Finally got the chance to take my Jimmy out this weekend, found out a lot of things I still need to do to my rig. (Don't we all?) Anyways, the item requiring immediate attention is where I've destroyed my driver side front shock from draglink contact. Obviously cross-over steering would fix this issue, but I don't have the money to address this at the time and I don't have the money to keep replacing front shocks.
    Sooo...anybody else have this problem? I run a 4" steering correction block under my steering arm, but do I need to run a dropped pitman arm as well?
    Thanks,
    Lance
  2. Lance
    Mar 4, 2002
    606
    Birmingham, Alabama
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    well how much lift do you have?...relocate the front shocks with some ford shock towers? $18 bucks a piece, drill a few holes and bolt them on..
  4. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I don't know your exact setup, but i had a 4" lift with dual shocks and I had this problem. I removed the front shock and the problem was solved. You have three choices: 1. crossover 2. relocate or remove a shock 3. Buy stock in rancho. Good luck.
