draglink for 8inch lift
Discussion in 'The Garage' started by dheavychevy38, Oct 21, 2003.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    the one i have is worn out do you know were to get a new one or the ends that go into it ??????????????
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    you can just get new ends from your local parts store.
  3. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    do you know what the part #'s are cause i can,t find them
  4. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    autoscoan sells it, it might come up under tie rod end, or somthing, but i know they sell the ends and the sleve. /forums/images/graemlins/thumb.gif
  5. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    You can always take your old ends in and find the right ones.
  6. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    been there tried that no dice did you guys use the originals or the some other one cause the stock ones are to long for the bent sleeve
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nope they're drag link ends. The adjusting sleeve is available too.
  8. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    thank i will check it out tomorrow right after i fix my broken frame behind the steering box
  9. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    sorry to repost but i stil can't find the right ends the closest ones i found have a different taper going into the steering arm the stock ones are to long cause the sleeve is s shaped any other ideas would be great
  10. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Shouldnt you just be able to buy ends with the right thread pitch and dia.? When I was looking into hemi joints on mine, all the wanted to know was the thread pitch and diameter and they would fit. /forums/images/graemlins/confused.gif
