Draglink Problem
Discussion in 'The Garage' started by cdh, Jul 15, 2004.
  1. cdh
    cdh Registered Member
    May 6, 2002
    69
    Gilbert, Arizona
    I installed a new draglink a couple of months ago, and it has started to make a cracking or snapping noise when I turn the wheel (mostly when I turn to the left). With the wheels on the ground if I pull back and forth on the draglink I can reproduce the sound. Should I replace the draglink, reinstall, let it be, etc?
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Shouldnt make a noise, I'd say remove whatever is making the noise and replace. Are you sure you greased it well?
  3. cdh
    May 6, 2002
    69
    Gilbert, Arizona
    It worked well for a couple of months and started to make noise. I have greased it a couple of times since installation. Good thing I bought NAPA lifetime parts. I have had nothing but problems with NAPA parts for the last couple of years, and the draglink was my last purchase!
  4. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    Ive got a used drag link you are welcome to try just to make sure the noise goes away /forums/images/graemlins/thumb.gif
    BTW- why did you replace the drag link in the first place, same noise or another problem?
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Is anything visibly loose in the draglink. Could the hole in the steering arms (axle or steering box arm) be egged out? Also you may want to check the frame by the steering box as those are notorious for cracking and causing the noises you describe (pulling on the draglink would simulate steering and causing it to pop as well). Just some alternate (related) things to investigate if the parts are as new as you say.
