draglink q's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dheavychevy38, Mar 23, 2004.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    draglink q\'s
    if i have a 8 inch suspension lift and run a raised steering arm with a dropped pitman arm can i use a stock draglink?
  2. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    Re: draglink q\'s
    You'll have to most likely put it together and check the total length and the angle... you want the drag-link to be near level, this will keep it from binding on the ends..
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Re: draglink q\'s
    There is also a drop drag link kit that works with the stock fron-back set up. It is good for about 4-5" of drop. You can also go x-over (a sway bar is moot on an 8" lift).
