draglink q's
Discussion in 'OffRoad Design' started by dheavychevy38, Dec 13, 2003.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    draglink q\'s
    you are a 4x4 genuis what do you think of this problem i have a 8 inch lift with steering correction 38' tires adn 10 bolt axles every time i go out wheeling the draglink ends are junk any ideas
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Re: draglink q\'s
    Are you overangling the ends? That's the first thing I'd check. If you are, you need a drop draglink or some other method to flatten the angle on the ends.
  3. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    Re: draglink q\'s
    not sure but i think you have the right idea i have a 8 inch superlift no swaybar welded diff which is a 10 bolt and 38 '' tires the steering mods are a raised steering arm and a draped draglink
    if i do crossover steering and change to a 60 is the arm that bolts to the nuckle the only thing different
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Re: draglink q\'s
    For the crossover, you need:
    2wd steering box
    pitman arm
    steering arm
    draglink and ends
    Not much transfers from the 10 bolt axle. Actually, nothing transfers over.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: draglink q\'s
    did you say you have a welded 10 bolt? Spooled and welded front axles put lots of strain on steering components, you never mentioned that before.
  6. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    Re: draglink q\'s
    sorry i forgot to mention the welded part i am going to put in a open carrier and limiting straps on the diff to try to cure the problem or do you think the open carrier will do the trick ????
    got to make something work to late febuary thats when my 60 should be put in
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Re: draglink q\'s
    I would say the cure is the D60 with crossover and hydro assist. Everything else is just trying to mitigate the symptoms.
