Draglink question
Discussion in 'The Garage' started by MTBLAZER89, Apr 5, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Not gettin much traffic here so ORD
  2. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    /forums/images/graemlins/dunno.gif /forums/images/graemlins/ears.gif
  3. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Sorry, I have no idea /forums/images/graemlins/dunno.gif
  4. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Well I called ORD an the lady on the phone told me No they wont interchange, but she also told me that you can't use the same pitman arm. Both axles have the same WMS to WMS measurement /forums/images/graemlins/confused.gif I just want to know why if they wont interchange. /forums/images/graemlins/dunno.gif
  5. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    Is the reason they won't work because of the pitch of the arms? Don't the 60 high steer arms angle down away from the wheel?
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Well the lady on the phone said they both use the same TRE's on the ends. I just want to know why the draglink isn't the same?
  7. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    It is a length issue. The x-over 44 DL is about 2" longer than a D60 IIRC. The D60 arm is direcly above the pivot point (king pin) The D44 is 1.5" away from the pivot point (ball joint). You could go and cut the DL down a little and re-tap it. I don't know the exact differences in length however.
  8. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    exactly what he said, I though t I had a problem too, but then I talked to the guys in the shop, call back with a measurment ( I think the D60 one is 37.5") and they will replace it if it's wrong. /forums/images/graemlins/thumb.gif
