draglink
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ROCKBUGGYK5, Mar 15, 2001.
  1. ROCKBUGGYK5
    ROCKBUGGYK5 1/2 ton status
    Jan 2, 2001
    170
    TEXAS
    hey guys i got a question i have a 79 k5 blazer with a dana 60 frontend raised steering block 4 inch tuff counntry leaves with ord shackles and i can turn real far to the right but not much at all to the left do i need to lengthen the draglink or shorten it to gain more steering to the left thanks again
    adam
    ROCKBUGGY K5 38S LOCKED AND CHOPPED
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Shortening it (if you have enough adjustment) would help. Just look at it and it should be obvious how it works. With only 4" you shouldn't need a x-over with a dropped arm and block.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
