Draglink???
Discussion in 'OffRoad Design' started by camok5, Feb 23, 2004.
  1. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I just put a custom 6inch Deaver spring lift on my blazer, 2 in the rear with a ORD shackle flip. The blazer is my daily driver and I have a swaybar disconnect, the springs are way to soft to run crossover and I have bent drop draglinks before from jumping it. My question is there another option like a stronger drop draglink or maybe a custom pitman arm( I already have a raised steering block)? /forums/images/graemlins/thinking.gif
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Have you tried a raised steering arm? That's the route I would try. Then, if you need more correction (which you probably won't) you could try a 2" drop pitman arm. We have the 4" raised arms for $65.00, they're pretty cheap and relatively easy.
  3. offroad87
    offroad87 Registered Member
    Feb 2, 2004
    57
    Atoka, TN
    how much $$$ for the 2" pitman arm?
  4. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I just ordered my drop pitman arm and it was about $90 bucks. Thanks ORD... /forums/images/graemlins/thumb.gif
