Drainable/fillable 14ff diff cover
Discussion in 'The Garage' started by Ned Kelly, Apr 14, 2007.
  1. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Since I do alot of mud/water, I want to put a filler bung and drain bung on my 14ff diff cover. I was thinking a very small fine thread nut and bolt on the bottom for the drain, and a larger (maybe 3/4" or bigger) fine thread nut (and bolt for the plug) welded to the upper half of the stock OEM cover.
    Any other suggestions?
    I don't think I need and armoured diff cover as I'm not in a rock environment.
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Better off to get a piece of bar stock and then drill and tap a pipe thread in it then weld that piece to the diff cover and use a pipe plug.
  3. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    X2, use pipe thread (NPT).
  4. robert97dodge
    robert97dodge 1/2 ton status
    Mar 7, 2007
    706
    Lufkin, Tx
    Or you can do like a buddy of mine always does and just drill a hole in the bottom of the housing and tap it.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yeah but if you want the maximum strength and have your housing shaved, I wouldn't recommend that idea at all.
    KidJethro was making covers for a while with fill and drain plugs. Doesn't make them anymore though. I would have liked to pick one up before he stopped, oh well.
  6. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
  7. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Kert, DIY4X, can also add a drain plug, he put one in my razorback cover
  8. Ned Kelly
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    I"m going to get the Great Lakes Offroad cover. thanks guys.
