draining the radiator
Discussion in 'The Garage' started by wraenking, May 9, 2004.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    ok, i see a small plug at the bottom right side of my radiator (when looking at truck) is this the only option? it seems like when i go to drain it, it will go all over the place?
  2. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    You are correct, it will go all over the place. Not much you can really do about it. maybe just crack it so it will dribble out, but then that would take a long time to drain.
  3. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    ok, thanks. i think i will rig something up with a tube and shutoff valve when i reinstall it.
  4. camok10
    camok10 1/2 ton status
    May 1, 2004
    288
    Tucson, AZ.
    thats a good idea, just make sure that whateva you use will be able to stand the pressure, (its not ALOT, but still /forums/images/graemlins/cool.gif) i think normal cap pressure is like 16 psi? But still that hose idea works out well. /forums/images/graemlins/waytogo.gif
  5. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    they might even make something already. ill have a look aorund and post what i find.
  6. JSH
    JSH Registered Member
    Oct 20, 2002
    75
    Iowa
    You should be able to slip a piece of tubing (3/8 inch id?)over the draincock to help direct the flow. Remember not to leave the coolant sitting around-pets love it and it can kill them.
