dreaded saggy butt but only on drivers side!?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Apr 9, 2002.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    posted this in the garage and only got one reply.
    what should i do? my drivers rear spring is sagging but the pass. side isn't. it sags enough to effect the stiff pro-comp front springs too, the whole drivers side is sagging a little more than one inch, alomost 2 in the back. should i get new springs? if i'm getting new springs i might as well get 4" lifted ones, huh?
  2. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    sometime it has to do with engine torque and such. I'd switch the springs to opposite sides and see if it evens out in a couple weeks. - Doug
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    my dads is a stock height 1990 3/4 and his sags to the driver side and sits with the rear end low.
    S-10's lean but they lean to the passenger side.
  4. dyeager535
    26,975
    I'd say the same thing...swap sides. At least they'll be easy to remove if you have to replace them : )
    Mines "unevenly sagged" in the rear, but I couldn't figure out why, since it stayed that way when I swapped springs side to side. Why? Checked frame height, axle height, all was pretty even. Turns out the passenger FRONT spring is "taller" than the passenger one, (by about 2") and pushes the drivers rear down.
  5. dbltapp
    dbltapp 1/2 ton status
    Apr 25, 2001
    133
    Maine, but moving again.
    My sub does the same damn thing, and i have a 2 1/2" lift that is less then a year old! Please share what info you come up with, thanx. You sub looks great by the way.
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    485
    Grand Rapids area
    This is really common. It can come from different sources, including body mounts and rear springs. Assuming that none of the leafs is broken, it could be helped a little by loosening up the spring eye bolts and making sure that they are all tightened when the body is level.
    It has been discussed before, so you can search for it.
    In my case, the two rear springs are really obviously no longer arched the same. Not wanting to spend a lot of money, I just tried a small block on one side and it worked out really well. The truck even rode better afterwards. It's still there to this day.
  7. muddysub
    Jun 23, 2001
    10,451
    489
    thanks guys! i'll swap sides and see what happens. after a while i'm gonna get a 4" shackle flip so i might repladce the springs while i have em removed.
