Dremel cutting accesories
Discussion in 'The Garage' started by Bubba Ray Boudreaux, Oct 18, 2002.
  1. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Is there a Dremel accesory that will slice and dice a rotor real good?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    A rotor as in a brake rotor? That's some heavy duty metal we're talking about. But, there are many discs out there for the Dremel tool made for cutting metal. Stay away from the composite material cutting discs. They probably won't work. There is a company (blanking on the name) that sells cutting wheels (little metal discs with wicked little teeth) for Dremel tools. Your local hardware store should have them next to the Dremel accessories. They work well for cutting through bolts and whatnot. A rotor...I'm not sure.
  3. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Man thats thick as all H3LL for a dremel to cut! I'm thinking Plasma torch or band saw, hi-pressure water knife! Why do ya need to cut a rotor?
    /forums/images/graemlins/confused.gifBill
  4. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Grinding out the inside to fit over an axle flange. I found the tool, worked great but I would still be out there. So I went at with the grinder, got a good solid heavy cutting disc that took me about an hour, but it's gonna take a lot more work, so I think I'm gonna go back to Thumper's design since that looks like it would be better.
