drifts right
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Greenie, Aug 14, 2003.
  1. Greenie
    Greenie Registered Member
    May 11, 2003
    28
    Glendale Arizona
    I have an 89. The truck drifts to the right. All new tie rods, drag link shocks, springs (2" skyjacker springs, front and rear).
    New tires, even rotated. New ball joints.
    What would cause it to drift. Does not matter what the road is like. Always goes to the right.
    Also have a light vibration under acceleraton. I have a NEW driveshaft. The rear is anlged.
    Any help???????????
    /forums/images/graemlins/1zhelp.gif
  2. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    tire wear, tire inflation, you might of hit somthing really hard with your front right tire while you were drunk and cant remember, j\k. but check your tire pressure. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  3. Greenie
    May 11, 2003
    28
    Glendale Arizona
    tire pressures are all even. I can't afford to drink. Price of gas out here is insane!!!!!!!!!!!!!1
  4. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    when you installed the ball joints and or the tie rods did you get an alignment? You should have your toe could be out of specification or your caster-camber could be off. something bent, axle spindle etc. Look for the obvious, dragging brake one wheel bearing tighter than the other etc. Good luck. Slider
