Drill another hole in the spring perch to relocate the axle?
Discussion in 'The Garage' started by 88K5Jimmy, Mar 25, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Did a search but came up empty.
    Could you drill another hole in the spring perch to relocate the axle or would there be too much stress put on the spring perch causing problems? My reason would be to relocate the axle without an add-a-leaf, or zero-rate offset. Also would doing this and have shims be a problem?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Doing it with shims will definately be a problem because the shim would be hanging off of the spring perch. You'd be better off drilling gthe springs anyways. </font>
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    You can redrill the perch and spring plate but only about 1 1/2" before the bolt is no longer pinched between the two. Going farther could lead to a broken spring pack right at the bolt so keep it sandwiched between the two. You could potentially run a shim as well, but you would have to redrill the shim to match, depending on the shims, this might not be possible. There are a bunch of people making steel zero rates which not only offset the axle but also have a degree taper built in to them. Its a slick way to take care of all three in one shot.
  4. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    I made my own zero rates which moves my axle back 1", now my next dillema is the driveshaft, I allready paid for it but before it gets made I need to kick up the pinion angle a touch, I already re welded my perches twice, different story, and I don't want to doit again, so I was thinking of tapered offsets, how do I figure out what degree they need to be? Mike
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I moved my back axle back 1" by drilling another hole 1" forward in my spring perches (that I made). You will also have to notch the spring plate. The front axle would be harder because it is cast and not mild steel.
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I did this on my front axle and it worked great. It ended up moving 1.25" forward. It made such a difference in fenderwell cleareance that I'm thinking of going back to a 4" spring.
