drill bits & air drill
Discussion in 'The Tool Shed' started by K5Chris, Apr 8, 2007.
  1. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    so, i need a 29 piece drill bit set for drilling metal. are the titanium or cobalt coated bits worth the money? snap on wants 180 for their bits and matco wants 160 something for irwin bits. not about to spend that much. i'd spend $100 for a decent set.
    what do yall think about these? or you got a better suggestion.
    http://www.thetoolwarehouse.net/shop/IRW-60138.html
    http://www.thetoolwarehouse.net/shop/IRW-73138.html
    http://www.thetoolwarehouse.net/shop/IRW-3018003.html
    http://www.sears.com/sr/javasr/product.do?cat=Power+Tool+Accessories&pid=00964073000&vertical=TOOL&subcat=Drill+Bits&BV_UseBVCookie=Yes
    http://www.sears.com/sr/javasr/product.do?cat=Power+Tool+Accessories&pid=00964086000&vertical=TOOL&subcat=Drill+Bits&BV_UseBVCookie=Yes
    my other question is, I bought an IR 7803 1/2" air drill.... it's nice, very powerful, but takes damn near forever to drill in steel, because it's slower. I used a coworkers 3/8" high speed air drill, and it cut a whole lot quicker. Is there a bit that works better for my slower more powerful drill, or should I just get a high speed 3/8" drill and stick a 1/2" chuck on it?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Make sure to get good bits. Sears generally doesn't carry alot of good bits from my experience. You are better off finding bits at places that are more supply houses for trades or Grainger or something.
    Cobalt bits are great for heavy steel with a slow speed drill. If you spin cobalts fast you will burn them up in no time. Titaniums are the ones you want if you want to spin bits fast and not kill them as quickly. Cobalts tend to be stronger then titaniums though so get the right bit for the work you are doing.
    Harley
  3. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    if you want a good set of bits... answer one question..
    1/2" chuck or 3/8" chuck
    then pick the drill
    pdr3a=3/8 air drill
    pdr5a=1/2 air drill
    dbtb129=29 pc set, full shank
    dbtr129=29pc set reduced shank
    dont go cheap, go good
  4. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
  5. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    From what I have seen, 1/2" drills are geared lower. My Snap-on 1/2" is 800 RPM, if it was too fast it would rip my arm off it if the drill hung up. I only use mine for large holes. I ended up getting a surplus aircraft 3/8" on ebay, it is 3000 RPM. I would recommend staying around 2000 RPM unless you are drilling sheet metal.
  6. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    those irwin bits matco sells are very nice though, I just got a set s couple weeks ago when they were on promo
  7. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
    The Irwin from Matco also have a warranty. I just replaced 1/8 1/4 3/8 for free.
    I have used them on sheet to 1/2 material including leaf springs.
