Drill size to tap and use a 5/8" bolt
Discussion in 'The Garage' started by Mudstud, Dec 30, 2002.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Drill size to tap and use a 5/8\" bolt
    I have a 5/8th threaded bolt (pitch 11) and I need to drill and tap a hole for it. What size drill bit do I use for the hole? Is there a simple rule of thumb to go by when drilling/tapping holes?
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Re: Drill size to tap and use a 5/8\" bolt
    9/16 th's. A good rule of thumb is a 16'th smaller, especially when drilling with a hand drill.
    John
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
  4. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Most charts say 1/32" smaller. The downsides to this are drillbits that are sized in 32's are $$$$$, and when using a hand drill you wobble a little, making the hole slightly larger than the stated size of the drill bit. A 9/16th bit will work fine.
    John
  5. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    By using a 9/16 insted of 17/32 will give you less thread to work with....especially if your hand drilling.....Not a good idea...stick with the chart. If your looking for a drill and tap try: www.mcmaster.com
  6. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Doh! I was tinkin' 19/32" /forums/images/graemlins/rolleyes.gif
    John
  7. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    So then you would use a 1/2" drill bit? Sounds reasonable.
  8. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Normally, when I drill and tap a hole, I go a 1/16th smaller, but most of the time that is with a 1/2" or smaller bolt, so the threads are not going to be that deep. I would assume (I hate doing that) that drilling with a 1/2" bit and tapping to 5/8" would work, but I would be awfully cautious as not to break the tap. A broken tap can be a nightmare.
    John
  9. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    use the chart Triaged put up.....you need to use the standard..... /forums/images/graemlins/k5.gif
  10. gmule
    gmule 1/2 ton status
    Apr 2, 2002
    196
    Conifer Colorado
    37/64th is the drill size you need
  11. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    It's all about the amount of thread contact you want....a friend of mine is a machinist and described it to me once (though I didn't fully understand all of it)
    The smaller you can drill the pilot hole (and the more precisely!) the sharper the edges of the threads will be....I think there is even a specification for different amounts of thread contact area on machinists drawings...?
    Anyway I just think of it as the larger the pilot hole, the more "squared off" the tapped threads will be, and hence the less strong they will be.
    If possible, use the bit in the drill guide and drill the hole in with a drill press (vs. hand drill)...if it is a critical connection point....
    /forums/images/graemlins/smile.gif
  12. boots
    boots 1/2 ton status
    Nov 3, 2002
    183
    Foothills of CA (Mariposa)
    from my machinist manual on CD
    TDS=OD*1/n
    TDS= Tap Drill SIze (in inches)
    OD = Outside Diameter
    1 = constant
    N = number of threads per inch
    NOTE: THis formulas will determine a recommended decimal size, then use numbered, lettered, or fractional size drill that is closest to the computed size
