Drilled Rotors
Discussion in 'The Garage' started by IGOR, Jul 4, 2003.
  1. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    So - just for something different, I tried drilling a pattern into my rotors - other than eating drill bits, it's okay - and I think it definitely adds to the rig! - and at LEAST 10 HP per rotor!
    Whatdaya think? /forums/images/graemlins/thumb.gif
    Rotors
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    looks cool i wonder if it'll help.
  3. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Not bad, now just groove it for slots =)
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    NICE! I want a set of drilled and sloted one but no one seems to make them. You did use a dill press right?
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    damn nice /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  6. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
  7. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    Actually I did not use a drill press - don't have one yet - would be much easier with one though - just taking my time with a hand drill. /forums/images/graemlins/thumb.gif
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Make sure you chamfer the holes on both sides!
  9. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    ricetastic!!! /forums/images/graemlins/tongue.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
    j
  10. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    sweet deal... looks sharp, but do they work? real world testing to come?
  11. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    What are the possibilities of the holes/slots getting clogged up with mud and what-not from offroad use?
  12. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    probably not a whole heck of a lot. Even it it does clog up, the constant vibration and heat cycle should clean them out I think.
  13. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    Real-world testing is definitely coming in the near future - I'm not building this damn thing to let it sit in the garage - (although my wife wonders sometimes!) /forums/images/graemlins/grin.gif
    I thought that same thing - about them clogging with mud - but then came to that same conclusion - it'll eventually fall out - or at least really throw my $hit off-balance! /forums/images/graemlins/grin.gif
    I think they're gonna look /forums/images/graemlins/pimp1.gif behind my Mickey Classic IIs - these wheels have huge holes in them so the caliper/rotor is pretty easy to see... /forums/images/graemlins/thumb.gif
  14. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Can you resurface those with a regular lathe? Wouldn't the holes be hell on the carbide bits?
  15. Confedneck
    Nov 1, 2002
    5,236
    actually yes you can resurface them on a regular lathe as once you set the bits they stay at that point..
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    They're going to crack, I'd be willing to bet.
  17. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Really? most shops I know cant/wont resuface a cross drilled rotor. (and yes, most of the ones I know of have cracked).
  18. BigBurban350
    Jun 9, 2002
    711
    Michigan
    Did you go through bits, how many? Or did you just sharpen the bits. Valve grinding stones work well, I can get them to bite pretty good.
  19. Confedneck
    Nov 1, 2002
    5,236
    heres the thing about cross drilled rotors, they shouldnt warp as easily as regular vented rotors, and if you cut them a LITTLE at a time you shouldnt have problems...but you might..ive been told countless times that you can resurface them "carefully"....would like to try it out sometime so i can give a definate answer
  20. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have tried to surface both slotted and cross drilled. Both chattered and had a horible surface finish when I was done. They were flat (no bell on them) so I just ground them.
