Drilling 57" center pin holes. Mutha%$^&%*&
Discussion in 'The Garage' started by Corey 78K5, Feb 9, 2004.
  1. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Drilling 57\" center pin holes. Mutha%$^&%*&
    What a beotch that was /forums/images/graemlins/mad.gif Spent most of the day redrilling the center pin holes in My 57's, and I have the 5 leaf Bronco spring packs not the 3 leaf F-150's. All I can say is thank God for the Drill Doctor /forums/images/graemlins/waytogo.gif
  2. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Re: Drilling 57\" center pin holes. Mutha%$^&%*&
    Cool.nice talking to ya the other day.you got the# if you still need it.good luck with your project,hp /forums/images/graemlins/thumb.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Spring steel is HARD stuff! /forums/images/graemlins/eek.gif The local spring shop charges $5 per hole to make new holes for ya. /forums/images/graemlins/yikes.gif
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I did all 10 leafs for my 57's in an hour and a half with a 1/2" hand drill in my backyard. No drill doctor (you cheater.../forums/images/graemlins/laugh.gif)
    I needed to sharpen the bit twice (5" grinder clamped in the vise was my 'drill doctor'). I kept the drill speed well below recomended rpm for the size and used a 3/16" pilot hole. Lots of lube for the bit too.
    Rene
  5. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    I must have gotten some soft springs. /forums/images/graemlins/whistling.gif I drilled both spring packs and I'm still using the same bit for other things, with no sharpening /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
  6. Corey 78K5
    13,055
    Humboldt County, CA
    Yeah My problem was cheap bits and a POS drill press that went way to fast /forums/images/graemlins/crazy.gif Oh well I'll soon have them in. Oh these are the 3" wide ones I was telling You about. a little fab work here and there and they'll fit /forums/images/graemlins/waytogo.gif
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Cool! Take some pic's and do a write up...my write up evaporated. /forums/images/graemlins/yikes.gif
    Rene
  8. Corey 78K5
    13,055
    Humboldt County, CA
    Sure that sound cool. I'll check with the "Big Guy" on it. Oh I also have "project door cut outs" comeing in a few months as well /forums/images/graemlins/peace.gif
  9. DwarF
    DwarF 1/2 ton status
    Mar 29, 2001
    226
    Austin, Tx
    Drilling my 57's sucked root! It took a week. I tried it with a Harbor Freight drill press, and ultimately just gave up on the damn thing. Once I got to use a shop's press, it took about 10 minutes. Just popped right thought them, same bits.
  10. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    I tried drilling brfore...sucked!
    I didn't bother trying to change the holes when I did my front 57" setup; just let the axle run farther forward. Someday I will acualy do a writeup ... keep forgeting to grab my meashurements from the shop.
    I think it ended up being 3-7/16" farther forward, giving me about a 5" lift and a 70degree approach angle. Real happy with the way it works.
  11. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Drilling Sucks. I just put mine on backwards. Stretched the wheelbase out about 6 inches, got about 5" of lift w/ shackel reversal, and the pinion angle is perfect w/ no shims!
