drilling and taping cast diff housing?
Discussion in 'The Garage' started by tweaker, Jun 26, 2005.
  1. tweaker
    tweaker 1/2 ton status
    Mar 21, 2004
    263
    Modesto, CA USof Freakin A
    i want to know if anyone here has experiance drilling and taping on cast. and how well it works etc. my d60 has one good bolt and the other keeps just spinning and doesn't grab at the base like it used too. at least my d44 i could just replace a broken u-bolt closest to the pumpkin.
    thanks in advance
    Dillon Carson
  2. dyeager535
    26,976
    Shouldn't be any different than an exhaust manifold stud replacement, also cast.
    If the area is large enough, I'd recommend a thread-sert. They require a fair amount of surrounding material though, as you drill the hole out to the next size that will leave "virgin" thread area, then tap it with a standard tap, and install the threadsert which brings it back to stock bolt size.
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I think he's using the wrong size bolt currently and that might be why he thinks he needs to repair the bolt hole. On our club website he says he would rather use the new 5/8" fine thread bolt instead of the 9/16" course bolt. I thought ALL GM D60's used 5/8" x 11 bolts from the factory? :confused:
