drilling and tapping the frame
Discussion in 'The Garage' started by surpip, Oct 11, 2004.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    is the frame think enoughto drill and tap, im talking about the bottom part of the frame. I want to put a skit plate over my tank, and the easyest way would be able drill and tap holes in the frame, so i dont ahve to take the tank out to get a nut on the back of the frame
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    yes it is. why drill and tap, just drill a hole and then use a TEK, self tapping screw. or even a Kaylon would be better and quicker then drilling and tapping each hole.
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    well i have access to any tap i need, all the drills i need and i want it to be strong, prety hefty skid plate fot the tank. It just dosent look very thick, not shure how many threads i would get /forums/images/graemlins/dunno.gif
  4. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    It is probably too thin--the frame is only about 3/16 thick,that means only one or two threads--not enough for a heavy plate that will get bashed.You could use Nut-Serts,they are like a pop rivet with a threaded internal sleeve,or use those "clip nuts"like on the fenders,only larger diameter,like 1/2 inch-- you could make the skid plate overlap the bottom rails of the frame and bolt another peice of flat stock to it that goes above the bottom rail to "sandwich"it,or make supports that bolt to the sides of the frame,where there are holes already(personally I hate drilling any holes or cutting anything out of a frame--its usually weak enough already!). /forums/images/graemlins/crazy.gif
  5. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I dont think the threads would last... there wouldn't be to many to hold it tight, one hard knock and it could strip /forums/images/graemlins/dunno.gif.
  6. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    Off the top of my head, I don't know how thick the frame is, (maybe between 1/8 to 3/16). What size threads are you going for? The smaller the bolt diameter, the more threads you can make in the frame. If you went with a 3/8 bolt, you probably won't get more than two or three threads.
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    how bout weld some 1/8 flat stock to the bottom of the frame and drill through that?
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    im thinking 3/8 bolts or what ever i can get for free from boeing /forums/images/graemlins/waytogo.gif
  9. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    just drill a hole in the frame and weld a nut on top. /forums/images/graemlins/thumb.gif
  10. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    thtas a good idea but i would have to drop the tank and i dont want to
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    That might work, but watch the heat around the gas tank /forums/images/graemlins/eek.gif
  12. dyeager535
    26,980
    Yes it's thick enough to drill and tap. No the threads won't hold up to abuse. They use fairly good sized self tappers on the brake and fuel line holders.
    I think the idea of using the e-nuts or whatever they are called (the spring steel ones that clip over flat pieces of metal with the nut on one side) is a good idea, as long as you aren't in the rust belt.
    I've got my factory skid plate off, but I can't recall how it's held in place, and I'm not there to look. I would speculate that since it was an option, all the frames (are we talking Blazer?) are setup for them.
    In any case, if this is a Blazer, I'd use a factory skid plate and save myself a lot of work. You can pull the factory plate without removing the tank or the hitch.
  13. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    well i already have the factory one, but i think its junk, the PO of my 73 made one ouy of sheet steel and it looks alot stronger, so id like to use that one, jsut looking at the eaisest way to mount it. on the 73 he put square pices of 1/4" steel that were tapped and fit tight to the frame acting as a back nut, but i dont think i have enough space between the frame and tank to put some of those in /forums/images/graemlins/dunno.gif
  14. dyeager535
    26,980
    I'm curious though, how thick a skid plate on the tank would have to be to actually support the vehicle. If anything, I suspect the stock ones were present to prevent the tank from being punctured, but as you I'm sure noticed, there is no way that thing will prevent the tank from getting damaged if you land on it.
    But, I would think, with the vehicles weighing what they do, a plate that could support the vehicle, as wide and long as it has to be to cover the tank, would need to be very thick to do much more than the stock one, or be designed with reinforcements across the span.
  15. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ya thats true, but ill be dooing alot of rocks so i think any improvement is good /forums/images/graemlins/dunno.gif
  16. dyeager535
    26,980
    I'm sure it's been dealt with by other rock crawlers, first hand knowledge will be the best to follow.
  17. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    My 1991 GM Factory Service manual says the only time that you should ever drill out the flanges is when repairing a crack.
    Other than that, they even have a dimension for how close to the flange you can go on the vertical portion of the frame.
    Needless to say, I have some eye-bolts on my 88 S10 /forums/images/graemlins/ignore.gif that break this rule.......................................
    Take it with a grain of salt... /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/screwy.gif
  18. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Just go muddin. No rocks. Remember what the doctor told you about those kidney stones?
    /forums/images/graemlins/histerical.gif
