Drilling spring perches
Discussion in 'The Garage' started by 4whler, Apr 4, 2004.
  1. 4whler
    4whler Registered Member
    Nov 6, 2003
    12
    Middle of TX.
    Can you drill a new hole in your spring perches on a d60 1" back to move your axle forward.If not what is the best way. I searched to no prevail.
  2. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    I would not want to drill on a D60, I would buy a set of ORD Z-rates and use the offset holes to move it /forums/images/graemlins/thumb.gif
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    k, this is a good question.
    a few people have made thier own blocks and plates to move the axle FWD. ne being BadDog. he has pics in his thingy i think.
    anyway, i used ORD zero rates. then since im using a 2 inch longer shackle, and needed to move the hole in the spring plate fwd as well i decided just to buy some shimmed spring plates.
    anywhoo. you would be better of using zero rates of one type or another. this is a good time to look into shimming if needed as well.
    Grant
  4. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    I redrilled my D60 perches 1.25" back to move the diff forward. No problem...
    Why make a job 10 times more difficult than it needs to be? /forums/images/graemlins/dunno.gif
    Rene
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I redrilled mine with no problems at all. I use my rig hard too. I also moved it 1.25" forward.
    Go for it. Its cheap and easy to do and you dont have too mess around with blocks and longer bolts.
