drilling spring perches...
Discussion in 'The Garage' started by jekbrown, Dec 13, 2003.
  1. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    tryin to relocate my front axle and I wanna do it by drilling the spring perch 1" back from center. Since the spring center pin is 9/16" (ie, bigger than my 1/2" bits!) how should I do this? Would a dremel and a lot of time/effort be enough to bore it out a lil bigger if I got the holes drilled to 1/2" first?? I know the hole wouldnt be flawlessly uniform, but would it be an acceptable way to do it?? I used a center punch to locate the drill bit where I want it and the factory perches on my d60 seem like pretty soft steel.... any1 else done this?
    j
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    The easiest way is to use a 9/16 drill bit. /forums/images/graemlins/deal.gif
    But as long as a you ground uniformaly, the dremel should work. You are only taking off 0.0313" in every direction. /forums/images/graemlins/thinking.gif /forums/images/graemlins/thumb.gif
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Just go and get yourself a 9/16's drill bit, you can pick them up really cheap /forums/images/graemlins/thumb.gif
  4. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    You need a stepped drill bit to fit into your chuck. MSC has them or any machine tool supply place.
  5. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    you will need to also pick up an even larger bit to drill the spring plate. i think you need a 5/8 or bigger. i forget how big the nut is corner to corner.
  6. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    9/16" is the drill size you need, you can get one with a 1/2" shank to fit your drill motor...or just use a zero rate with a off-set hole... /forums/images/graemlins/thumb.gif
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Be careful and don't get it to close to the edge. If you do, it will make fatigue failures at the pin location much more likely. Ideally the pin area should be well stabilized, clamped between the the perch and plate.
  8. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    plates arent a problem, i have JKW's 3/4" thick solid steel spring plates and they are already machined to allow for the axle relocation... its just the perches I have to worry about. I pondered selling my current zero rates and getting the newer ones that have the offset capability... but I just dont like the idea of a spring pack with 2 seperate center bolts in it. I'd much rather have the packs with just 1 center pin and just mounted to a offset in the perch.
    I dunno where u guys are finding these "cheap" 9/16" bits that can drill through steel... all the ones I see are $pendy. /forums/images/graemlins/confused.gif
    anyway, thanks much for the input... Im gonna go ahead and get em bored out to 1/2" tomorow morning and go from there. /forums/images/graemlins/laugh.gif
    j
  9. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    the big is 10 bucks at lowe's..
    go buy it...
    then go back later and say it dulled right up (which it will)
    and get your 10 bucks back... /forums/images/graemlins/shocked.gif /forums/images/graemlins/eek.gif
  10. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    lowes eh? If the hole was already at 1/2"... it shouldnt be much work for the bit to get it up to 9/16"... hmmm... $10? /forums/images/graemlins/thinking.gif
    j
  11. reddog64
    Nov 9, 2000
    3,325
    i bought a 3/4 inch drill bit for 16 bucks...
    returned it 2x (3 bits total) to be able to drill 3 knucksles otu for TRE's...
  12. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Why would a HSS bit dull after two holes in mild steel?
    Rene
  13. got_mud
    got_mud 1/2 ton status
    May 9, 2003
    316
    Wichita, KS
    Rene
    lack of lubrication and incentive to get a refund.
  14. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Hmm, sounds kind of like fraud to me /forums/images/graemlins/shocked.gif
    Maybe that's why it is so hard to run a business these days.
  15. TONYP
    Aug 13, 2002
    2,116
    so cal
    Rene
    main problem is you can't hold it steady enough, the bigger drills will chatter and dull the leading edge when done by hand...now if you could somehow clamp the zero rate to the leaf pad and use it as a drill bushing (put the drill through the zero rate hole) it will hold the drill in place and extend the life some...good luck /forums/images/graemlins/thumb.gif
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I agree. I refuse to put extra holes in the spring pack for new center pins. Others do it and get away with it, much like many other questionable practices, but it's simply over my threshold of comfort. I made 2" offset bolt in plates for my front axle that are longer than stock plate/perch in the offset direction so that the spring area around the pin is still fully stabilized. I also put a radius on the edge and a blend to eliminate the sharp edge for the spring to work against.
  17. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Rene
    I should have added a smilie to my comment >>> /forums/images/graemlins/rolleyes.gif<<<
    Drill rpm and technique will keep that bit sharp for a long time even without a drill bushing/guide. Just because a drill motor will spin at 1400 rpm doesn't mean that's the ideal speed for every size bit you have. Keep it slow, and if all you're doing is enlarging a hole keep the pressure on the bit very light and let it do the work. I have bit's up to 3/4" that I've had for probably 10 years or more...
    I drilled new center pin holes in my 57's with a 1/2" drill motor, 7/16" bit for the larger Ford center pins, and I drilled through 10 individual leaf springs without dulling or chipping the bit.
    Purposely dulling a bit to take it back for refund is pretty 'low' IMHO.
    Rene
  18. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    yeah, cant use the zero rate as a guide, the hole Im drilling is larger than the hole in the center of a zero rate. /forums/images/graemlins/grin.gif
    anyway, on my way to lowes now... gonna bite the bullet and get a 9/16" bit.
    BTW, what kinda clearance around a center pin should a spring perch have? how much is too much?
    j
