Drive Flange Kits D60, ONLY $135!!!!
Discussion in 'Vendor Forum' started by OffroadOverstock, Apr 10, 2006.
  1. OffroadOverstock
    OffroadOverstock 1/2 ton status
    Mar 28, 2006
    105
    Tulsa, OK
    ATOR wants to say thanks to all of the forum members that have faithfully seen them through the transition from Wagoner Machine Shop! Use the promo code ck5 to get an instant $59.95 rebate on the highest quality Dana 60 drive flange kit made!
    Supplies are limited, sale is good until supply is gone or April 30, 2006.
    Shipping is calculated before you pay on our secure site.
    GO HERE TO BUY NOW!
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    i have these on my K5 as we speak... very good gear.
    j
  3. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    how come there is 4 holes in the cover and only 2 in the gear? I really wanna buy some, but this has kind of got me puzzled.
  4. OffroadOverstock
    Mar 28, 2006
    105
    Tulsa, OK
    The cover doesn't attach to the gear....just the ring. The gear holes are only to aid extraction. A floating gear is better. Order quick we sold almost half our stock today.
  5. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    cool, just ordered.. thanks
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Those look great. I can see how the cover attaches but if a floating slug is better then how are you preventing the axle from walking inboard and allowing water and dirt to enter the spindle area past the seal that needs to be held tight against the spindle?
  7. OffroadOverstock
    Mar 28, 2006
    105
    Tulsa, OK
    A snap ring.
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I understand that you use a snap ring on the end of the stub axle but if the slug floats there is nothing to keep the axle from moving inboard. Now i can see if you have to find the original large spring that was used with a factory slug that it would work but you make no mention of needing one and it wouldn't be easy to locate one either.
  9. OffroadOverstock
    Mar 28, 2006
    105
    Tulsa, OK
    The snap ring on the stub is optional. I don't use them. There are no limits to how anal you want to get with axles. Bottom line...this is a long time proven method. By the time you read this we will probably be sold out. :wink1:
    Warn Kit:
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Like i said, nice looking product. If you believe for one minute that the snap ring on the axle stub is optional then you are highly mistaken. If they were optional why did the factory install them on every axle that left the factory? Also that is what keeps tension on the stub axle against the seal for the spindle.
  11. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    are flanges only available for 35 spline outers?
  12. OffroadOverstock
    Mar 28, 2006
    105
    Tulsa, OK
    Yes, but we have 35 spline chromo outers for $104.95 on our site too! :D
  13. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    most flanges I have seen (only exception I can think of are the poly perf ones) aren't thick enough for the snap ring to help put tension on anything. There is about 2" of splined-depth for a slug to fit in, and most slugs are like an inch thick. How is a snap ring on the end of the stub going to add "tension" to anything? I mean, you can put one there, but I don't see it really doing much of anything.
    j
  14. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Have you ever pulled apart a fulltime front axle with slugs in it? If you have you will notice that there is a very large spring that pushes against the backside of the slug which in turn pushes against the snap ring which in turn pulls the axle outboard to keep tension on the seal against the spindle.
    Maybe people haven't seen the way it is from the factory or the fulltime axles people have taken apart had already been into and someone removed parts but i can get you picks of the spring and also the cup washer that the spring sits in if you want.
  15. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yep, I'll agree with this. When I tore apart my full time axle to put manual hubs on, right behind the slug is a big spring that pushed against the slug which pushed into the snap ring.
  16. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Here is a pic of everything except the cup washer and snap ring. [​IMG]
  17. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I think koldsimer had to make something for his slugs becaust the axle would move in and the yokes would hit the tube. Makes nice sparks at night.
  18. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    cool beans, I'd like to see some pics... never taken a fulltime axle apart...
    j
  19. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Hmmmmm,says $295.95 ea.
  20. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    yeah, but then I'll need chromo inners too.
