Drive flanges?
Discussion in 'The Garage' started by SUB-ZERO, Nov 12, 2005.
  1. SUB-ZERO
    SUB-ZERO 1/2 ton status
    Oct 8, 2002
    219
    Virginia Beach,Va.
    I have been seeing people talk (or mention) drive flanges but nobody really explains what the purpose is.I did a search and couldn't find a good explaination.Other than strength what is the purpose?Is it the same as what comes on a stock full-time 4x4?Can you use it with a part-time case?What about a daily driver?Any problems associated with it(ie,lockers)?
  2. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    you hit the nail on the head. A good set of flanges is always stronger than a good set of hubs. They are usually cheaper too...
    No, because you can put it in 2wd with the t-case.
    yep.
    Personally, if I had them on a DD I'd pull the pucks unless I was going to go into 4wd. Shouldn't cause any problems for your locker.
    j
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    they are like lockouts that are locked in all the time. if you ran them on a DD your front axleshafts, diff, d-shaft, and t-case output would spin. i have heard of some people running them with a balanced front driveshaft and not having any problems.
  4. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    I ran them in my K5 and didnt have any problems with 42's front detroit, and hydro assist. It wasnt for the faint of heart though.
  5. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    Iv got them too and as long as your axles and u-joints will hold up they are great. never worry about a broken hub again.
