drive gear replacement (speedo)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mccomas, Jan 29, 2004.
  1. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    can someone point me to a reference for removing my drive "speedo" gear. my shop manual does not talk about the removal of the tail end of the transfer case. all the information that i found on line talks about 2 wheel drives with the drive gear installed in the tail shaft of the transmission. again, i am looking for some type of reference that will walk me through the removal of the drive gear. thanks...
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    Remove your speedometer cable and driven gear out of the tailshaft. Then remove the tailshaft housing, and the gear should slide right off of the tailshaft. /forums/images/graemlins/thumb.gif
    Rick
  3. mccomas
    May 30, 2003
    262
    Fayetteville, NC
    rick, i see the bolts that hold on the xfer case tail shaft housing - looks easy. i was not sure if a buch of crap was going to fall out once i removed the cover. will i need any type of seal puller or is it just a gasket? thanks...
  4. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I just used black RTV sealant on mine and it held up fine. The only piece that's a pain in the ass is the black disc that goes between the tailshaft and main housing. It has to be lined up right before you can bolt it back up. It only goes one way, but it doesn't like to stay put when putting the tailshaft back up. /forums/images/graemlins/thumb.gif
  5. dyeager535
    26,980
    If it's something that likes to slide off during assembly, vaseline or automatic tranny assembly "grease" (I've seen it used at tranny shops, but no idea what its called) might make the job a bit easier.
