Drive gear teeth on a NP208 on a 86k5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by U235a4, Feb 23, 2003.
  1. U235a4
    U235a4 Newbie
    Nov 3, 2002
    PA, US
    looking for some info on the drive teeth so I can find out what driven gear i need after bigger tires
  2. dyeager535
    26,977
    I'd say conservatively there are about 30 different drive/driven gear combo's for your year vehicle, so you'll have to figure out the correct ratio for yourself unfortunately...speedometer cable needs to turn 1000RPM's per mile.
    Unfortunately the speedometer gear section in the '85/86 parts manual doesn't specifically list 4WD applications vs. 2wd, and I have *no* clue whether 700R4 and NP208 drive/driven speedometer gears are the same pieces.
