Drive Line Brakes
Discussion in 'The Garage' started by ProJunkRacing, Nov 25, 2005.
  1. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    Who runs driveline brakes , are they legal , how much and are they easy to install?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    What do you mean by driveline brakes? If you mean a rear output mounted e-brake, don't run one but it is legal and they work well.
    If you mean pinion brakes, you can't run them on a normal axle. The rotor would be a few inches off of the ground sitting on level pavement.
    Problems with both driveline e-brake and pinion brakes, if an axleshaft, driveshaft(not an issue with pinion brakes) or something else down the line fails, you have no braking. Also you have to deal with all the slop of the driveline. Any slop in the driveshaft, backlash of the ring and pinion, play in axleshafts, all that will effect it.
    Eventually I plan to put a tcase e-brake on my S10, just not at the moment.
    Oh and I know in the state of Pennsylvania these systems are legal. Parking brakes have to be a seperate system from service brakes, and there is no specification for mounting point of either service or parking brake, just a requirement of performance, which is easy to meet.
  3. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    I am going to be running one from tom woods. It will take some fab work to get it to work but its alot better priced then some of the other kits around.
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    2wd SM420 trannies came with a output yoke e-brake, they have to be legal. I wish I'd kept mine.
  5. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    This is all true, most states require that the parking brake be a seperate system. They don't specify where that system is. When they inspect all they do is set it and make sure it holds on an incline.
    My tcase brake works better than the regular brakes. It has 5.38 times the stoping power :D As far as a broken driveshaft, I thought of that but when on the trail is doesn't matter as long as you don't brake both shafts. Now if I ever grenade the 205 and rear shaft simultaniously I guess that would require some wheel cholks :haha:
