Drive shaft 4in. lift
Discussion in 'The Garage' started by airassault, Mar 25, 2004.
  1. airassault
    airassault Registered Member
    Mar 25, 2004
    6
    Scottsville KY
    Will a stock front drive shaft work with a 4 in. suspension lift.
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Yes, but if you want to be absolutely sure you can have it lengthened like i am going to.
    So far, with some of the flexin i have been doin, mine has been ok though.
  3. airassault
    Mar 25, 2004
    6
    Scottsville KY
  4. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Basic ?
    What can happen without a longer d.s. and a 4" lift.
    (worst case scenario)
  5. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Not sure yet, but from what i can see, it would seem that the slip joint part of the driveshaft could possibly pull apart, again, not sure though as i do not know how long these parts are.
    Maybe somebody else on here has had one apart and can tell us how long they really are???
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    worse case senario, it pulls apart and flops around. if you and crawling minimal damage is done, but if yuor going faster than 20mph it can do some major damage /forums/images/graemlins/yikes.gif
    i had a front ujoint came of the yoke and punched a hole in the pan and killed my motor /forums/images/graemlins/yikes.gif/forums/images/graemlins/angryfire.gif
  7. big jimmy 91
    Feb 21, 2004
    639
    Not to H.J. this thread but ,does the rear d.s. also need to be loger with a 4" lift? (susp. lift)
    any advice appreciated.
    /forums/images/graemlins/ears.gif
  8. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Nope, i am using both stock driveshafts.
    Again, it would be nicer to have maybe another two inches or so as the lift has cause it to pull out slightly from the rear of the t-caes, but it has been working fine for me so far.
  9. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    my d.s on my sub is good, I haven't flexed it out yet but I have a lot of slip...
    justin /forums/images/graemlins/burb.gif
  10. big jimmy 91
    Feb 21, 2004
    639
    Thanks for the info /forums/images/graemlins/wink.gif
